FS B6T rods!
Old 04-27-2009, 02:25 PM
mx-3_4evr's Avatar
Default FS B6T rods!
$120 Shipped! Need them gone today!
mx-3_4evr is offline
Old 04-27-2009, 03:27 PM
mx-3_4evr's Avatar
Sold!
Old 04-27-2009, 04:03 PM
Saml01's Avatar
Are these identical to just plane jane rods in our engines?
Saml01 is offline
Old 04-27-2009, 04:26 PM
mx-3_4evr's Avatar
No, these are supposed to handle 300HP+ They came out of a 323 GTX (1st gen B6T engine)
Old 04-27-2009, 04:32 PM
thesnowboarder's Avatar
"supposed" to handle 300+ hp huh?
I guess 230 whp is kinda like 300HP+?
thesnowboarder is offline
Old 04-27-2009, 04:36 PM
1990miata1.6's Avatar
lol i ran 20psi on these rods with no problem and made 250whp uncorrected
1990miata1.6 is offline
Old 04-27-2009, 04:47 PM
Saml01's Avatar
They look straight up identical to the rods i have sitting in a box right here next to me.
That tells us nothing because there are people running 250+ hp on the stock rods. If you are confident then you should be able to make more then that.
Saml01 is offline
Old 04-27-2009, 05:29 PM
mx-3_4evr's Avatar
Here is a comparison... From right to left: GTR, BP, B6T
Old 04-27-2009, 06:26 PM
Saml01's Avatar
Youre right, im blind.
Saml01 is offline
Old 04-27-2009, 06:44 PM
ThePass's Avatar
Total Cats: 1,216
quite curious what they actually are supposed to be good up to...
someone just got a great deal if those are good for 300.
Ryan Passey
ThePass is offline
Old 04-27-2009, 07:05 PM
the 250whp was uncorrected so if you do the correction its 300whp. soo if you want to look at it this way there good for 300whp
Old 04-27-2009, 07:14 PM
i would have a machine shop check them for cracks who ever bought them
Old 04-27-2009, 07:35 PM
mrtonyg's Avatar
Total Cats: -2
That is a good size difference...definitely beeffier!
mx-3_4evr do you have a scale to weigh a rod? Just curious.
mrtonyg is offline
Old 04-27-2009, 08:45 PM
The rods used in the 88-89 323GTX turbo are beefier. They have a thicker beam, thicker small end and larger size bolts. They weight approx 580 grams (w/bolts and nuts) vs the approx 540 grams of the Miata rod. The GTX rods are no longer available new from Mazda and the Miata pieces supercede it.
http://www.solomiata.com/Mx5Engine.html
Old 04-28-2009, 05:25 PM
djcommie's Avatar
I have some crazy hybrid 323 SOHC engine with DOHC capri n/a parts, I wonder if it has GTX rods...
djcommie is offline
Old 04-28-2009, 05:29 PM
mx-3_4evr's Avatar
Nope only 323 GTX (B6T engine) I took apart a Capri XR2 and it came with BP/B6 rods, so only the GTX
Old 04-28-2009, 07:30 PM
Can you take some measurements at the base of the rod for me? Im curious if i ever had gtx rods or just stock ones.
Old 04-28-2009, 08:21 PM
mx-3_4evr's Avatar
you can tell the difference on the caps... look at the pics
interestedofold
09-29-2015 01:42 PM
Dparks7
09-28-2015 09:49 AM
Quick Reply: FS B6T rods!
