Alternative to reverse cooper scooper
Old 06-30-2012, 07:16 PM
GrahamC's Avatar
Total Cats: 10
Default Alternative to reverse cooper scooper
Hi guys,
Thought you might like to see what I got upto this evening:
Started like this:
Then started cutting (used a dremel with some heavy duty cutting discs for the bonnet skin):
Ended up with a big hole like this:
Just sitting there - not bonded on or painted (obviously):
And from the rear:
It's a Subaru Forester S Turbo scoop from the year 1999 like this one:
And a bonus pic - I test fitted my GT3071R tonight and couldn't resist a photo:
Attached Thumbnails Alternative to reverse cooper scooper-7475335200_d2bfacc07a_b.jpg   Alternative to reverse cooper scooper-7475333008_cb5a9a86f3_b.jpg   Alternative to reverse cooper scooper-7475331292_8fd047ab54_b.jpg   Alternative to reverse cooper scooper-7475329862_4d999eca76_b.jpg
GrahamC is offline
Old 06-30-2012, 11:32 PM
Mobius's Avatar
Total Cats: 365
Looks like it will look good once it's finished. Are you going to add any structure back across the interior of the opening?
Mobius is offline
Old 06-30-2012, 11:38 PM
rleete's Avatar
Total Cats: 1,264
That hole is huge. Looks like it ought to do the trick.
I still can't bring myself to start cutting mine.
rleete is offline
Old 07-01-2012, 02:04 AM
TorqueZombie's Avatar
Total Cats: 64
I want. But don't want to. It my hood. Call it fear of messing up the one hood I have. If I found another '99 hood in silver it would be game on. Drunk
TorqueZombie is offline
Old 07-01-2012, 03:32 AM
triple88a's Avatar
Total Cats: 1,803
Does it sit flat on the hood or are there gaps in places?
triple88a is offline
Old 07-01-2012, 07:40 AM
Laur3ns's Avatar
Show pic of underside?
Laur3ns is offline
Old 07-01-2012, 08:32 AM
GrahamC's Avatar
Total Cats: 10
Sits perfectly flat on the leading edge but there's a tiny gap at the rear because the centre of the scoop overlaps the hump on the bonnet. Nothing huge - we're talking 1-2 mm. Nothing that couldn't be sorted with a couple of rivets. Didn't take a pic from the underside but will do.
GrahamC is offline
Old 07-01-2012, 09:07 AM
wannafbody's Avatar
Total Cats: -369
I think a simple approach would be to cut the 3 round holes out from underneath and trim with some door edging but that wouldn't flow nearly as much air.
wannafbody is offline
Old 07-01-2012, 09:34 AM
GrahamC's Avatar
Total Cats: 10
I wouldn't worry a out cutting out the structure. It's still got plenty of strength left in it and isn't floppy at all.
GrahamC is offline
Old 07-01-2012, 10:23 PM
ZX-Tex's Avatar
Looks functional. I like it. Where did you get the scoop from?
Based on where your hood pins are, and assuming you are not using the stock latch, you might have the same issue with your hood that I did. I added a scoop that is similar in size to that one. The hood is still strong enough with the removed bracing. However at medium to high speed the front edge of the hood will lift up from the top edge of the bumper and open up a gap. This is the opposite of what you want. I added some bracing to pull the front edge of the hood back down and now it is not an issue.
Scoop
ZX-Tex is offline
Old 07-02-2012, 03:45 AM
triple88a's Avatar
Total Cats: 1,803
Weld 1/8" flat to each support after cutting them or just leave the supports in.
Old 07-02-2012, 08:30 AM
Originally Posted by zx-tex
carbontrix extractor
ftfy.
EricJ
7
09-11-2021 11:10 PM
ihiryu
General Miata Chat
09-28-2015 10:22 AM
b&t
09-22-2015 09:32 AM
ihiryu
7
09-20-2015 09:04 AM
Quick Reply: Alternative to reverse cooper scooper
