Android Crew: ITT we may assemble and discuss various, assorted topics
Old 08-15-2012, 11:36 AM
  #141
Samsung May Be Rolling Out Galaxy S3 Jelly Bean Update on August 29th | The Droid Guy
Bros,
Samsung is releasing JB at the end of the month, this means most of you will get JB in Spring, I'm on Sprint and will wait until 2015 for my JB update.
Old 08-15-2012, 02:28 PM
  #142
VAmazda's Avatar
Jellybean is great, I'm on 4.1.1 on a vzw Incredible2. Aeroevan rom + capacitive buttons disabled so I can try out on-screen buttons full-time.
I like it, but the screen scaling seems off on my phone since it's a bit of a hack, but a well-done hack nonetheless.
Fingers crossed HTC releases ICS for it soon so the real nerds have some source code to work from.
VAmazda is offline
Old 08-15-2012, 08:41 PM
  #143
krissetsfire's Avatar
Total Cats: 56
pls fedex tissues so that I my cry into them and find a new line of work.
honestly I dont care about quad core. my single snapdragon core in my original Droid Incredible is fast enough most of the time except when apps are updating. when they are updating, **** happens on a "you will wait" basis. it sucks *****.
does having the second (third, fourth) core eliminate that issue so that background tasks like app updates and syncing dont bring the UI to a standstill?
Y8's I only have a dual core processor and my **** feels slow during updates. i'd suspect it's more of a memory issue than a processor issue.
krissetsfire is offline
Old 08-15-2012, 08:49 PM
  #144
Leafy's Avatar
Total Cats: 104
They always feel slow during updates. It hogs up a ton of resources. I have found the newer versions of android have been faster during updates than older, and with the new play store it will only download 1 thing at a time even on wifi, rather than downloading everything at once then installing them in order.
Leafy is offline
Old 08-18-2012, 02:58 PM
  #145
I'm confused. Is there anyway to make a back-up or image of my current, factory ROM as it sits now on the phone without rooting first? I'm want to install CM10, but don't want to "start over" if I go back to my factory ROM.
Old 08-18-2012, 05:02 PM
  #146
get titanium backup pro. you can back up your apps and settings with that and then restore them to a stock rom install.
of course if you're going to install CM, you're going to already be rooted and can do a nandroid backup then.
fairly certain you can root, nandroid, CM, restore stock, unroot. but check on that. nandroid really is the best solution for "how it was before"
Old 08-18-2012, 05:39 PM
  #147
I want an image of the phone the way it sits now, so I can return it if there is a hardware problem.
Old 08-18-2012, 08:11 PM
  #148
Total Cats: 56
i used nandroid to backup my phone but have never reverted to it. I've had my phone for 2 years so it's kind of moot. but as y8's said nandroid s kind of the standard for backups.
I was on jb for a week but went back to special version of gingerbread. since sprint is such garbage i got a version of gb that uses a different modem driver. I can now permanently roam on verizon with this combination of modem/software. I've been much happier. now my speeds are 10x faster and i don't randomly lose signal and miss calls.
Old 08-18-2012, 10:14 PM
  #149
Well, this has turned into a nightmare. I can't seem to get anything installed and I'm back on the factory ROM which sucks because I hate hate hate TouchWiz.
Old 08-19-2012, 09:27 AM
  #150
my googlage tells me you want to install something called odin. I guess it's a kernel with clockworkmod recovery built into it?
Install ClockworkMod ( CWM ) Recovery on Samsung Galaxy S3 Sprint
is that what you've been failing at?
Old 08-19-2012, 10:34 AM
  #151
I'm running ODIN and I've tried this with two TAR files.
  1. The phone works fine in Kies
  2. Shut-down Kies and double check the task manager to be sure it's shut down
  3. Put the phone into recovery
  4. Plug in phone
  5. Open ODIN
  6. ODIN finds the phone
  7. Point to the TAR file
  8. ...and then every time ODIN hangs on the NAND-write process and will go no further
Old 08-19-2012, 04:37 PM
  #152
Total Cats: 56
did you install your drivers on your computer first? also try another usb cable.
Old 08-19-2012, 07:32 PM
  #153
Leafy's Avatar
Total Cats: 104
Are you choosing phone or PDA in oding for the tar? you want PDA (at least this is how it is for the older galaxy phones). And make sure dont have format selected. Also see if you need a pit file too for your phone to work theoretically with mine you dont need the pit but I always have better luck with it.
Leafy is offline
Old 08-20-2012, 04:01 AM
  #154
richyvrlimited's Avatar
Is there a way of resetting the flash counter on the S3?
At's all well having a backup to restore to, but if the flash counter is incremented Samsung will still know you've been messing about with stuff.
richyvrlimited is offline
Old 08-20-2012, 09:35 AM
  #155
concealer404's Avatar
Total Cats: 2,201
Got ICS.
Battery life is half as long now, and picasa won't upload anything.
Sucks.
**** sprint.
concealer404 is offline
Old 08-20-2012, 12:32 PM
  #156
Total Cats: 56
Got ICS.
Sucks.
**** sprint.
I reverted to cm7 + nexus s modem and get 30+ hours with full use and wifi. was only getting ~16 or less on jb or ics.
Old 08-20-2012, 12:34 PM
  #157
Leafy's Avatar
Total Cats: 104
Ginger bread was my worst battery life rom, like worst than stock froyo or eclair. ICS has so far been about as good as most custom froyo roms.
Leafy is offline
Old 08-20-2012, 12:41 PM
  #158
I finally got the phone rooted this morning into CWM, now it won't go back there to install CM10. This **** is ******* gay.
Old 08-20-2012, 12:44 PM
  #159
Total Cats: 2,201
I have no idea what any of this means.
Old 08-20-2012, 12:47 PM
  #160
Leafy's Avatar
Total Cats: 104
Can you get it back into recovery at all? But only the stock recovery? I've had cwm need to be flashed a couple times to take hold on occasion. And I've also run into times where I couldnt get into recovery without entering by turning the phone on by inserting the battery. IE start with a phone with no battery, hold buttons for recovery, insert battery.
Leafy is offline
Quick Reply: Android Crew: ITT we may assemble and discuss various, assorted topics
