Fabulous Fabrication Post all your custom fabrication projects here; impress all your friends.
The custom fabrication thread! (Post pics of stuff you have made)
Old 10-25-2013, 06:10 PM
  #601
turbofan's Avatar
Total Cats: 1,004
just wow. Beautiful work. Props.
Ed@949Racing/Supermiata
www.949racing.com
www.supermiata.com
turbofan is offline
Old 10-25-2013, 09:01 PM
  #602
HHammerly's Avatar
Total Cats: 63
Here is a home made efr going on my project car, a 99 w PS and AC slow progress one hour here and there kind of pace
HHammerly is offline
Old 10-26-2013, 10:45 PM
  #603
3rdCarMX5's Avatar
That looks great. I'm thinking something similar. How are you going to route the intercooler? Looks tight.
3rdCarMX5 is offline
Old 10-26-2013, 11:35 PM
  #604
HHammerly's Avatar
Total Cats: 63
Don't shoot me but i am going water to air IC, a similar setup that i used on my M45 1.6 w AC and PS if it can keep intake charge cool on that 1.6 @ 8k it will do just fine on this much more efficient turbo setup.
I moved tha AC condencer 2" fwd and installed the oem radiator w u channel caps in its place for cooling the water and going w a koyo and sumitomo fans.
Old 10-27-2013, 08:36 PM
  #605
3rdCarMX5's Avatar
Use what you already have, I understand. You can always change later. Do you happen to have a jig for the manifold? Didn't you have a cad file with the flange?
Old 10-27-2013, 10:31 PM
  #606
HHammerly's Avatar
Total Cats: 63
I made a crude fixture with a head and turbo flange that positions each at the correct location relative to each other and then bolted the actual manifold flanges to it and build it from there, i would use 1-1/4 sch 40 but weld fittings insread of the 1-1/2 i used if i was to do it again, it will make the manifold more compact for a better fit and keep higher exhaust velocity most likley improoving spool; i am considering buildimg another one just for those reasons.
Old 10-27-2013, 10:33 PM
  #607
Leafy's Avatar
Total Cats: 104
Sounds exactly like what I did, except I did use 1.25 sch40 steam pipe. I also used solid works to print out 1:1 scale side views of each bend so that I could match them up perfectly when cutting.
Leafy is offline
Old 10-28-2013, 01:16 PM
  #608
HHammerly's Avatar
Total Cats: 63
I don't have SW and have been asking my boss to let me purchase a seat, for the time being i purchased Inventor LT suite on my own so i can draw parts and get by for the time being, one great trick i started using is a line laser from a small bench top drill that i use for marking the parts before cutting them, that saved a lot of fitting and sanding.
Old 11-06-2013, 08:37 AM
  #609
nitrodann's Avatar
Total Cats: 67
Adding to the twincharged post.
Dann
nitrodann is offline
Old 11-09-2013, 09:47 PM
  #610
shlammed's Avatar
Total Cats: 51
Start of a top mount BP turbo manifold for a CRAZY NB.
4-1 TiAL Vband Collector by HellaFab, on Flickr
shlammed is offline
Old 12-17-2013, 08:16 PM
  #611
Erat's Avatar
Total Cats: 800
This is the result of working in a shop where you're not the only welder.
I didn't have enough time to finish the other night, i come in today to find it "finished".
I think it's pretty clear where i left off.
Erat is offline
Old 12-17-2013, 09:32 PM
  #612
Leafy's Avatar
Total Cats: 104
At least the other guy choose to use the tig rather than a poorly setup spool gun.
Leafy is offline
Old 12-18-2013, 03:59 AM
  #613
Erat's Avatar
Total Cats: 800
Implying I used a spool gun?
Erat is offline
Old 12-18-2013, 07:14 AM
  #614
Leafy's Avatar
Total Cats: 104
I was making the ol' swicharoo joke.
Leafy is offline
Old 12-18-2013, 07:18 AM
  #615
Erat's Avatar
Total Cats: 800
I've used a spool gun once. It worked but it was kind of annoying to use.
Erat is offline
Old 12-19-2013, 09:53 PM
  #616
Supe's Avatar
Total Cats: 64
Nothing exciting, just welded up a rocker box for my roll cage down bars to tie into instead of floor plates. POS Matco MIG welder and .030" wire.
(Note: Looks like SS plate, but is just cold rolled strip)
Supe is offline
Old 12-20-2013, 06:27 AM
  #617
nitrodann's Avatar
Total Cats: 67
Dann
Old 12-20-2013, 08:32 AM
  #618
richyvrlimited's Avatar
That' looks really tidy Dan, very nice work.
Looks like you could almost get the OEM heatshield over the top for an ultra stealth install.
richyvrlimited is offline
Old 12-20-2013, 09:05 AM
  #619
nitrodann's Avatar
Total Cats: 67
Thanks, thats the idea, we will see how we go
Dann
Old 12-20-2013, 09:27 AM
  #620
shlammed's Avatar
Total Cats: 51
or a heatsheild from a Nissan sr20 manifold would likely fit even better, being that the manifolds are that general shape.
shlammed is offline
Quick Reply: The custom fabrication thread! (Post pics of stuff you have made)
